CT - Measurement + post "CT Sizing" 10/02/10 by jwparker
I have some questions around the same guys...
Retrofitting power monitoring to a sub-station which only has protection ct's fitted. It has been decided that 3 measurment ct's will be installed. Substation 66/11kV. Going on tx size, 400Amps seems to be max constant secondary. Protection CT's are 600:1 and the guy asking me to sort this for him has asked me to try and find 600:5 split core measuring ct since the sub will only be down for a short time - i am not sure if such a beast exists.
He is hoping to hook it to a satec PM175. (the existing protection ct's are hooked to a satec PM171E - off drawing)The PM175 specifies a burden of 0.1VA. I was wondering what voltage the PM175 would see at its input if 600:5 ct hooked up assuming primary current did get as high as 600amps? 20mV?
The other thing is i have had some guy tell me that a split core is available but isolation level is only 7kV - can someone guide me here - the cable it is going around is insulated etc photo attached
Thanks in advance ...
RE: CT - Measurement + post "CT Sizing" 10/02/10 by jwparker
Many others are available from other suppliers.
http://www.electroind.com/ct-split.html
