Pump size: adding to existing ground source heat pump well field
I am working on a school with an existing ground source heat pump system.  They are adding another small building.  The existing well field is large enough to handle the added load.  I have not done much with hydronics.  How do I size the pump for the new building?  Do I need to consider the head loss through the existing system?  Thanks!
RE: Pump size: adding to existing ground source heat pump well field
Need to see the configuration of the piping networks before we'd know the answer to that one.
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
http://virtualpipeline.spaces.live.com/
