Section View Standard
I think this is really not an issue but a small dispute between some co-workers.
First off, when you have only one section view on a drawing with a section line displayed in the main view, must a section view label (i.e. SECTION A-A) be applied or is it okay to omit the label because of only one section view?
Secondly, If you have a section view on a drawing, is it always required to have a section line in the main view or is it in any situation, assumed and okay to leave off? Any proof of support would be greatly appreciated.
RE: Section View Standard
2) ASME Y14.3M-1994, para 3.2 "The cutting plane may be omitted when its location is obvious..."
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
htt
John-Paul Belanger
Geometric Learning Systems
The following are basic Y14 standards. Your company should have copies of these:
ASME Y14.1- Drawing sheet size and format
ASME Y14.1M- metric sheet size and format
ASME Y14.100- Engineering drawing and practices
ASME Y14.2- Line conventions and lettering
ASME Y14.3- Multi-view and sectional view drawings
ASME Y14.4- Pictorial drawings
ASME Y14.5- Dimensioning and Tolerancing
ASME Y14.24- Types and applications of Engineering drawings
ASME Y14.34- Associated lists
ASME Y14.35- Drawing revisions
ASME Y14.38- Abbreviations
ASME Y14.41- Digital product definition drawing practices
ASME Y14.42- Electronic approval systems
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
In practice my understanding of the standard is the same as ewh states.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
