How to delete the marks created with Subgrid Solution?
I just calculated my model with ansys. After that, I used the "General Postproc--->Query Results--->Subgrid Solu" to creat the marks pointing out the maximum stress and minimum stress.
But I just cannot remove these marks when I found there were some mistakes about loads I had applied. It doesn't work even I made a new solving with new loads apply. They are right still there.
Could anybody tell me how to delete or remove these previous marks?
RE: How to delete the marks created with Subgrid Solution?
try,,, plotctrls>Annotation>create 2d annotation>
click the drop down menu to options, then either delete all or select the delete radio button and select the text you want to delete
www.priamengineering.co.uk
