Vertical Turbine Pumps
Does anyone know of projects where vertical turbine pumps have been installed? We are currently designing a pump station and have different options on the type of pumps we can use. One of the options comprise vertical turbine pumps. This prove to be the most cost effective option when compared to the others.
We are concerned about the reliability of these pumps. One pump typically delivers 650 l/s at 260m head. The vertical shaft of the pump will be approximately 9m high. We would like to contact clients who have installed similar pumps to obtain information about the reliability and maintenance cost of such an installation.
Best regards
Best regards
RE: Vertical Turbine Pumps
What sort of installation is it - fresh water, recycled water, mine water, etc etc....having some of that information may get you more useful contacts.
There are a lot of VT pumps in service, and if they're selected properly, they'll run forever.
Steve
