Defflection of connecting rod,under pretension,due to distributed load
I am analyzing a situation where a connecting rod (diameter 50mm), under pretension, is subjected to a distributed load over the entire length of the rod. How does pretension in a connecting rod (tie rod) effect the deflection (bending) characteristics of the rod due to the distributed load applied?
RE: Defflection of connecting rod,under pretension,due to distributed load
You might find this link useful:-
http:
beam+under+tension&source=bl&ots=v0sBTAqh48&sig=CSc5
Bgawkyqp555On0R4N9g1R5w&hl=en&ei=bBqZS8DZHKX60wS3kvD8Cw&sa
=X&oi=book_result&ct=result&resnum=2&ved=0CAwQ6AEwATgy#v=
onepage&q=deflection%20of%20beam%20under%20tension&f=false
desertfox
Is the rod subjected to a uniform load transverse to the axis, or is the load along the axis?
Is creep a design factor?
Material? Steel?
Does the rod have only noncompressible material in the grip, or is it acting like a sagging rod / stiff cable?
If there is no compression in the rod, stability is not a concern, and the tensioning effect actually reduces out-of-plane bending deflections slightly. Of course, maximum tensile stress is higher from the combined effect.
