Bizarre error that comes up only during analysis run..
I'm beginning to get more explorative with Pro/Mechanica and I'm trying to run some FEA on a simple pressure vessel. I've successfully run pro/m analysis on some simpler objects, so I'm pretty sure my process and everything is right.
The error I keep getting is this: "one or more surfaces have load but are not part of any element" which comes up in the status dialog of the run if you check it, and the run fails as a "critical error" / "engine failure"
I can't figure out exactly what this error means. my model is a cylinder with a revolve as one endcap, and a mirror of it as the other endcap. It passes the model check, but it keeps quitting due to this error. If I remove the pressure loads from the endcaps (both of them) it will run analysis on the cylinder wall without any problems... So my issue is the endcaps somewhere/somehow... But I cant think of what. Do I need to constrain/define that they're connected to the cylinder wall or something?
Help/thoughts/opinions are greatly appreciated.
RE: Bizarre error that comes up only during analysis run..
It's never simple to imagine the situation without seeing what and where are geometry, constranits, loads..
I solved my own problem... It turns out the revolution for the one end (and the mirror of it at the bottom) were done as surfaces... and they should have been solids.
Thanks!
