MAWP Jacket
MAWP Jacket
MAWP Jacket
I got one.  I have a ASME code pressure vessel with a dimple jacket.  The jacket was assumed to be rated at 75 PSIG @ 575F MAWP, but the U-1 indicates its 45 PSIG @ 575F.  Is there a process to get the jacket rating increased?
RE: MAWP Jacket
If I'm not mistaken, dimpled jacket manufacturers have done a proof test to validate their designs. I don't know that there is a way to rerate these, short of FEA.
Best Regards,
Michigander.
RE: MAWP Jacket
You might go back to original mfr if they possess an R stamp and see if they can "rerate" the jacket.  Dimple jacket designs are based off proof tests completed by the designer, so best to start there.
RE: MAWP Jacket
Get an "R" -stamp holder to perform a Alteration re-rating of the vessel.  Just run the calcs for the pressure/temp you are wanting and have a CI sign off on it.
