Detail View of Flat Pattern
Hello Everyone
I am having trouble with detail view of a flat pattern which is rotated. I have this trouble in multiple drawings so it is not one off case.
When I draw a circle for detail view it does not show me anything then I have to move the circle onto empty area outside the flat pattern & I will see the actual flat pattern. Seems like it is still following the flat pattern in the before rotation stage( 0 degree rotation.)
I am using SolidWorks 2008 sp4.0 so not sure if it has been fixed in the later releases. Please let me know if it is still a problem in SWX 2010.
or if there is any fix/solution for it? Or if I am doing something wrong?
RE: Detail View of Flat Pattern
Michael
