Translating the Language of Notes Within a .dft File
I'm trying to find a software solution that would allow me to translate the language of notes and other text contained in a Solid Edge drawing from one language to another. Ideally I would like to be able to this within the source .dft file, but it would be okay if I had to first turn the drawing into neutral a format.
I'm using Solid Edge v20 (will be upgrading to ST2 later this year) and I'm looking to provide prints to a Spanish speaking customer. In the future the language may be German, French, etc.
Thanks in advance,
Bill
Thanks in advance,
Bill
RE: Translating the Language of Notes Within a .dft File
I'd be surprised if you found one for dxf or similar though maybe as it's a bigger market.
You could copy and paste from the draft to a translation software however...
Using translation software without someone who has a good understanding of technical language in both dialects confirming the translation sounds a bad idea.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I haven't found any software solutions so far for SE or other formats, but was hoping someone has come across a similar challenge here that may have an idea.
We are looking for someone to proof read the translation as you suggest. With the volume of drawings I'm looking to translate, I was hoping to find a way to assist in this endeavor.
Bill
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
