Pipe anchor blocks
Pipe anchor blocks
Pipe anchor blocks
Hello
I'm looking for design criteria for anchor blocks that are used to anchor what we call "trickle tubes" in dams. These are essentially a 12 or 18 inch pvc pipe that is located about 5 feet below the crest of a dam. The tube runs on a slight slope then generally parallels the downstream slope of the dam before then bending to essentially horizontal and discharging. A trickle tube is used to control the elevation in an evaporation pond.
