Export of the ABAQUS data via Plug-in
Hi all,
I have a problem with Autodesk Moldflow Sructural Alliance interface for ABAQUS.
The export procedure is described below:
After preparing the model in ABAQUS(CAE version 6.7-1) it is necessary to - Select Plug-ins > Autodesk Moldflow Structural Alliance > Export Model . The Export Wizard appears (this may need to be maximized from the Windows Task bar).
How it can be seen from the image in attachment, Autodesk Moldflow Structural Alliance plug-in does not appear, so it is impossible to export the model to Autodesk Moldflow Insight.
Does anybody know how it could be resolved?
Thanks in advance for any advice.
