Reuse library part name and description
Is it possible in the reuse library to have the part number (filename) under the thumbnails and a description of the part popup in the tooltip as you mouse over the thumbnail?
RE: Reuse library part name and description
The 'filename' would only be that of the master Template file since until you actually select a 'family member' there is no way of knowing what the actual part file name will be, which also holds true for the 'description'.  Again, until you select a family member, the description would be not much more than what you can already learn from the name of the template file.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Sorry I should have clarified.  Assuming that the parts we put in there are standard parts, not family member templates or knowledge enabled parts.
Sorry, the system was set up to only display the part file name.  That being said, I can understand the value in doing this and so perhaps you should contact GTAC and have them open an ER to this effect.
John R. Baker, P.E.
Industry Sector
Cypress, CA
