PIPE SUPPORT
PIPE SUPPORT
Any suggestion where to put pipe support for a different services running inside tunnel. Sorry for the ignorance, its my first time to design pipe support.
Thanks in advance.
Thanks in advance.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: PIPE SUPPORT
Some pipes, most pipes, have thermal elongation issues and/or thrust forces that must be resisted. Also, the pipe supports are designed sometimes to move a bit to allow longitudinal pipe length changes.
You should talk to the pipe designer and find out what the potential is for movement.
RE: PIPE SUPPORT
www.SlideRuleEra.net![[idea] idea](https://www.tipmaster.com/images/idea.gif)
www.VacuumTubeEra.net
RE: PIPE SUPPORT
http://www.unistrut.com/
Depends on pipe sizes and materials, but I have used systems like this successfully in mechanical/plumbing chases and pipe racks for smaller diameters.
http://www.standon.net/products2.html
pipe stands for larger diameters
