Solidworks 2010 crashes after openeing *.sldprt file
I encountered a strange problem with SW 2010. I'm running Windows 7 Professional x64 edition. I installed SW 2010 certified drivers for Nvidia Quadro FX580.
I installed SW 2010 SP0 x64 edition at first. I started it and when I tried to open one simple *.sldprt file (made in SW 2009) SW crashed. It is interesting that I can open and manipulate *.slddrw files and it does not crash. The same thing happens when I try to open new *.sldprt file (SW crashes). When I open new empty *.slddrw file, SW works perfectly.
Nothing changed when I installed SP01.
From attachment you can see that *.slddrw file is opened and when I tried to open *.sldprt file it crashes and Windows show me that message - "Solidworks has stopped working" (sorry that it is in Slovenian language).
I'm guesing that it could be graphic related problem. If someone encountered same problem and resolved it please help me.
RE: Solidworks 2010 crashes after openeing *.sldprt file
2) Post a simple part file here for others to test.
3) Try resetting the registry.
4) Do a complete and clean uninstall/reinstall.
https://forum.solidworks.com/docs/DOC-1014
1) If I try to convert 2009 files to 2010 files using task scheduler it doesn't work or I'm doing it wrong. Whwn SW tries to convert file it opens and then crashes like I would open it.
2) I attached a simple file. If someone can try to open it, please.
3) I tried to reset the registry. It doesn't work.
4) Will try to reslove it first and then try clean uninstall/reinstall.
I've re-saved the file and attached.
I've tried clean install/uninstall and still nothing.
Can Anyone tell me what do I need to be aware of if I will install SW 2009 back. Clean uninstall of 2010? What should I remove from registry?
Try Launching SolidWorks in one of the RX safe modes. Are there any other parts that will open? It might be file specific problem. Try this with some other parts or try creating a new 2010 part and seing if the same issue occurs. If you have more issues see if you can get your VAR to open a SR with SolidWorks to Update your files from 2009 to 2010 as a last resort.
Michael
I'v tried to open a lot of parts, but it crashes at every part. Again I've tried to open one older *.slddrw file which is a bit more complex and it works (see attachments), there are some toolbox parts errors, but it works.
I've also tied to open file which CorBlimeyLimey saved in 2010 and it is still same problem.
Don't know what to try else.
When I try to open new part, SW crashes.
Thanks for help so far...
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Except I don't know where to turn software acceleration to "None" in Windows 7, because on that link it is for Windows XP. Is it under Nvidia control panel or under Windows control panel?
Thanks for help guys.
