3? power meter with ethernet
Hi there,
At my work, I have been given the task to find a 3Φ power meter that has an ethernet port and can communicate via TCP/IP.  This device will be permanently mounted and remote communication will be used to view the meter.  The meter will be monitoring the power supply to a ski resort with 15 lifts.
This power meter needs a built in web page that shows the data in a web page form.
Does anyone have any input?
RE: 3? power meter with ethernet
There are lots of meters out there that can do that. Try calling your local GE, ABB or Eaton salesman.
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
Alehman's right, there are tons.  Check e-mon d-mon for a lower cost version if needed.
Google "ethernet three phase power meter" to find hundreds more.
Let us know what you choose!
Good on ya,
Goober Dave
I did google it and there was plenty to choose from.  I was looking for recommendations on a specific one from an end user and I should have stated that in my original post.
ION meters from Schneider.
+1 to stevenal
ION meter, good solution
Looked at many options and went with the very reasonable HIOKI unit. It has done everything I needed it to do so far!
I've seen these Accuenergy meters and they seem to have decent specs and definately are cheap.
http://www.accuenergy.com/
