Autoclave Engineeers Medium pressure port
We are designing som test equipment which is going to be connected to a pressure system with Autoclave Engineers Medium pressure SFCX connectors. Connection type SF562CX20 for tube with outside dim of 9/16.
My question is how to manufacture the port correctly for this connector. What tolerances and surface finishes is required?
I have found the AE catalogues on the web, but they dont state othe than nominal dims and a weep hole without any information.
Anyone who knows how to do this?
RE: Autoclave Engineeers Medium pressure port
This sounds more like a fluid mechanics problem than one involving drafting standards. This may not be the best forum for it.
Have you tried calling the manufacturer, the sales representative, or your local vendor?
I went to their website and found the info you are looking for with little trouble, here is the link.
http://
John H. Dunten, CD
Certified Drafter
Yes, I know this document, but it doesn't state any tolerance for angles, diameters, depths or surface finnishes.
So when we recieve a manufactured part from a sub supplier we hasn't any limits to check it against.
Anders
