ASTM A350 LF2 Class1
I need to know what type of Charpy value I could get after normalizing and tempering ASTM A350 LF2 Class1. I tried normalizing only and results are just passing to minimum.
Thank you
Thank you
RE: ASTM A350 LF2 Class1
Why are you so concerned with the value? As long as you meet the minimum requirement, this is all that is necessary. Also, the minimum tempering temperature is specified in the ASTM specification at 1100 deg F. Review the specification.
Thank you
Double tempering at same temperature
Increase tempering temperature
Thank you
