Library of Socket Head Cap Screws?
Is there anywhere I can get a library of fastners, namely Inch and Metric SHCS?
Or do I have to make this type of component myself?
The Reuse library seems to be the right place, but it is only has hex head bolts.
Jay
RE: Library of Socket Head Cap Screws?
... to find under screw - socket head
when you have the latest (11.2009) Libs
The OOTB Machinery Library from Siemens is only partially complete.  There are some screw types that are not in it.  You may have to use an existing part in there as a template and make your own.
