Coal Efficiency
Coal Efficiency
Hi, I wonder what is needed to do as extra if we do give up using 400 kcal/kg coal to use a 300 kcal/kg one in a 250 Mwatt coal plant?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Coal Efficiency
Marmite
RE: Coal Efficiency
RE: Coal Efficiency
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
RE: Coal Efficiency
Bill
"Why not the best?"
Jimmy Carter
RE: Coal Efficiency
Still, I can't be very sure since you haven't told us what type of coal boiler you have there! Maybe it will work with your boiler setup or it won't! Best to have help from a boiler specialist.
