Taper of 1:50
Taper of 1:50
Taper of 1:50
Hi friends,
Please help me how to calculate the taper given as 1:50 in a slope is there any method how to calclate the taper.
Thanks in advance!
Srinivas
RE: Taper of 1:50
No, from your drawing there is no way to calculate the minor diameter.
RE: Taper of 1:50
1/50 = (D-d)/L
D = large diameter
d = small diameter
L = length of taper
or
D - d = L/50
Ted
RE: Taper of 1:50
Unless you give it as a function of length.blllttt
RE: Taper of 1:50
So, hydtools, what is the length ??
RE: Taper of 1:50
benta, I have no idea.  That's up to the srirou to decide.
Obviously it is a missing piece of information.  That is what the equation illustrates.
Ted
RE: Taper of 1:50
Inch taper pins are usually 1:48
Metric taper pins are usually 1:50
So d = D - L/48  inch sizes
   d = D - L/50  metric sizes
L is length of pin
RE: Taper of 1:50
Maybe I'm missing something.  Taper is simply rise over run, so 1:50 means 1 unit vertical to 50 units horizontal.  The angle is then arctan(1/50) = 1.14576 degrees.  If the taper is INCLUSIVE, then divide by two to get the face angle.
For example, I have a premium thread of 3/4 TPF (taper per foot)imperial.  This means 0.75 inch rise for every 12.0 inches of run ON DIAMETER.  The required angle is then 0.5 arctan(0.75/12) = 1.78817 degrees.  This would be the standard half angle cone for LTC threads for oilfield casing.  API listing is 1 degree 47 min.
You don't need diameter, just the understanding if taper is measured inclusive thereof.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
RE: Taper of 1:50
If you have the taper rate(1:50) you do not need to find the included angle, just use the ratio to find the unknown diameter for a known length.  1 unit diameter change for 50 units of length.
Ted
