Solving a System of Equations in Real Range in MAthCAD
Is it possible to solve a system of nonlinear equations in real range in MAthCAD??
I know how to solve an equation in real range, but system doesn't...
RE: Solving a System of Equations in Real Range in MAthCAD
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
I have found the solution, but it takes a lot of time,
because of presence of complex roots along with real roots.
I need only real solutions of system, so the question is
how to make MathCAD finds only real roots....
I know how to do that with single equation. (assume, x=real)
But I have no idea how to do that with an system of equations.....
You also have to beware of MuPad's German origins, so while it has precision, it can also be pedantic. Maple appears to have the opposite American view, often providing the 'common' answer, even if it is wrong (think integral (1/x) passing through zero..)
Start with a system of 2 equations, and build up to three, then four.
Do you have a worksheet that you can post for us to look at?
Pete
