countersink question
not sure if this is the correct forum to put this - is there a table referring to countersink dimensions? specifically I am after 90 deg countersink for 1/4. your tips will be greatly appreciated. thank you
RE: countersink question
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
However, are you sure you want 90° & 1/4?
Whey you say 1/4 do you mean a 1/4 inch screw? Inch fasteners don't have 90° heads, they have 8° or 100° unless a custom special.
Think long and hard about your function, bigjimbo makes a good point about material thickness. You also need to consider if the mating part has threaded holes or if you're using nuts. If threaded holes then you have a problem as both the head and the thread are fixed and cannot float. There are workarounds for this if your functional requirement is just to keep the heads flush or under flush, however they have stress and aesthetic implications.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
just redrafting this drawing, got the screw information additionaly, is .285 hole acceptable?
You don't usually use countersinks with a button head screw. A countersink is generally used to recess a flat head screw.
If you mean counterbore dia then .285 sounds far too small.
If you just mean what hole size you need, then you need to calculate this based on function. .285 isn't unreasonable so long as it meets your requirement and the tollerances of position on the holes and the mating parts are set appropriately. I think the suggested normal clearance holes for 1/4" in Machineries is .281 which I believe corresponds to a fairly standard counterbore tool.
So, with the information you present I have no way of telling you if .285 is acceptable.
If you are talking counterbores instead of countersinks, then .285 is too small as maximum head diameter on a 1/4 buton head cap screw is .437
You should buy Machinery's Handbook or reference one.
