GPD for Football Stadium/Baseball Field
I am in the process of designing a lift station to handle the waste from the restrooms at a high school track/football field (approximately 2,500 seat capacity), a softball field and baseball field. My fixture unit count is 42, though would like to find some flow numbers. Closest I have found is for a picnic area, which was 5 GPD/person. Any help would be appreciated.
Thank you.
Thank you.
RE: GPD for Football Stadium/Baseball Field
For a football stadium, you assume that half the crowd will use the facilities at halftime. Each flush would be 1.6 gals. This would occur during a 15 time interval (halftime).
The peak flow will be less for a baseball stadium than for a football stadium because there are more time breaks.
As you have determined, the best estimate will be based on using the fixture method.
h
