THICKNESS OF ROTATING WHEEL
Dear All
I am designing a water turbine but I am not sure to calculate the thickness of the end plate holding the blade rows. This end plate act as a loaded rotating wheel, transmitting 300 KW at 820 Rpm. as attached.
Could anyone give the applicable formula??
Thank you
RE: THICKNESS OF ROTATING WHEEL
If this is a  Pelton Wheel here are the design parameters.  if you want the know everything about the design of a Pelton Wheel checkout the book.
http://en.wikipedia.org/wiki/Pelton_wheel
"The Micro-Hydro Pelton Turbine Manual," by Jeremy Thake.
