How to calculate pressure in pipeline
Hi all,
Could you please help me. How to calculate pressure in closed pipeline.
I have 8 km, 1" line fill with hydraulic oil. The pipe will be laid at 40m depth in the sea. I can calculate volume of Oil in the pipe, but how to calculate, how many liters of oil will need to increase pressure to for example 100 bar.
I need formula to show the connection between Volume and Pressure.
Thanks in advance
Thanks in advance
RE: How to calculate pressure in pipeline
You should be able to work out a formula from the above.
David
You mean that, I need to know hydraulic oil compressibility. Probably the vendor can give me this info.
If I know how many liters I need, then I can calculate how many minutes my pump will running.
Dian
Just to insure that we have the correct understanding of your problem, David and I too assume that your question was regarding only to do a pressure test on that pipeline and it was not at all related to finding any necessary pressure to flow some quantity of oil in that pipeline. Correct?
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
http://virtualpipeline.spaces.live.com/
If you want to check longitudinal elongation due to pressure and evaluate extra-amount of oil to compensate it (very low in this specific case, but sometimes not trivial) you can use the formula below:
Epsilon = [(P*D)/(4*t*E)]* (1-2*Poisson)
Where :
Epsilon = longitudinal strain
P =applied pressure
D= pipe mean diameter
t = pipe thickness
E = Pipe Young Modulus
Poisson = Pipe Poisson's ratio
