Involute Spline on shaft and hub
Hello all, no matter what settings I try, I always fail to produce a spline in a hub bore using the connection generator. I can get the spline into the shaft, but not the hub. Is there tutorial for this, using inventor 2008 pro.
Thanks in advance
Thanks in advance
