Compaq Visual Fortran: problem in linking library
I've been using Compaq Visual Fortran for some time.
Now I've a problem about linking library: when I build the code, it appears this error: error LNK2001: unresolved external symbol __initializefonts and others LNK2001 errors.
To solve this error, it needs to add graphic library. I've identified the correct library to add from the help menu, but after adding this library and building again, unfortunately this problem persists.
Why?
Many thanks
Why?
Many thanks
RE: Compaq Visual Fortran: problem in linking library
