Alternative to screw captive idea
In our assembly section, we use electric nut/screw drivers. Because, they are magnetic, the fasteners are captive in the tool and makes it easier with lesser handling.
Now, I am looking for ideas on similar lines to drive a stainless steel fasteners. Are there any ways to reduce the handling time. Because these easterners aren't magnetic, not the assemblers as to hold the tool, faster and the parts to fasten simultaneously. Its difficult.
BT
BT
~ BT
RE: Alternative to screw captive idea
Most stainless steel fasteners are austenitic stainless, which is not magnetic. Ferritic stainless is. I could have that terminology backwards.
How about some sort of socket head? Hex socket head cap screws are easy to get. Robertson or Torx sockets may be available if you look hard enough.
Would a hexagon head screw work for you?
Harold
SW2010 SP1.0 OPW2010 SP1.0 Win XP Pro 2002 SP3
Dell 690, Xeon 5160 @3.00GHz, 3.25GB RAM
nVidia Quadro FX4600
www.lumenflow.com
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
h
When I am designing something that requires the assembler to hold on to an inaccessible screw, I specify hex socket head cap screws. I know that these remain attached to a horizontal driver. Robertson screws mostly are self-tapping wood screws. They also remain attached to a horizontal driver, and you can apply lots of torque to them. They might be available as machine screws in stainless, especially if you need a lot of them.
Torx screws look to me like they would work, but I have never actually handled one. I am not sure I own a Torx driver.
I just remember the manufacturing guy saying how they worked with autofed drivers or something.
