varying diameters on single cylindrical boss-extrude?
First post here.
I am looking for the most efficient way to model a cylindrical shape with stepped diameters along its length.
As a simple example, imagine a barbell with a large diameter (weight) on one end, then a small diameter handle in the middle, then back to a large diameter weight on the other end.
I understand how to do this with multiple boss-extrudes, or by revolving a stepped profile, but is there a way to do it with something like a single boss extrude whose diameter changes at different points along its length?
I hope I'm explaining this clearly. Thanks.
First post here.
RE: varying diameters on single cylindrical boss-extrude?
http://www.EsoxRepublic.com-SolidWorks API VB programming help
In your sketch you can create a series of concentric circles. They can all then be used to create a single protrusion feature, but with different limits for each region.
This would enable you to create a stepped bar in one feature.
Alternatively use a revolved feature.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Dan
www.eltronresearch.com
Dan's Blog
If "most efficient" = fewest features, then a Revolve-Extrude fits the bill.
