Total power required to compress a volume of Air
I need a discharge of 12cu/mtrs of air in 1 minute at a pressure of 1.4 bar, could someone assist me with the calulations to find to total power required in kW to achieve this.
Cheers
Cheers
RE: Total power required to compress a volume of Air
To get help, it really aids the process to state your problem clearly, with enough data to allow some willing soul to try to solve the problem. You did neither.
David
I require a constant flow of 12cu/mtrs of air per minute at 1.4bar & require help to calculate to power required to achieve this..
There may be an SI version or you will have to convert your numbers to imperial.
Do you mean 12 m^3/min at 1.4 bar?
Ted
12 M^3/min*(40/12)^3 *1.4*14.7*144/33000 HP=1.16HP
