Image to Texture
Image to Texture
I want to add a certain picture on one part in the assembly.
I can already use an image in *.par so I can see this on the surface. But when importing this part to the assembly the image gets lost.
Anyone has an idea how to handle that problem?
Regards.
Regards.
RE: Image to Texture
Or you can do textures in view/format faces but I dont' think that's what you want.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
thank you very much. The first answer is exactly what I`m looking for. But how to show that component sketch in asm?
Context Menue:
Show/Hide component => Sketches
But the problem is the sketches are shown all. Is there a further hint?
If you wanted the sketch to show in your draft file you can opt to just show that one.
Its an area where SE could improve - give users the option to list sketches and constructions etc in the Pathfinder.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Also, you can define a style with the image as the texture.
It`s no really an option for professional drawing to work the way with deleting all the other ones.
@BMLKIDD: Where did you apply that image. In the part file (how?) and the ASM I could, but I would to it in the part.
Open the part file.
Go to Format --> Style --> Face Styles
Click on "ORTHO" - then Texture tab - point the texture to the location of the image.
Ensure that "Textures" is checked under Format -- > View
Once you've defined your face style, go to Part Painter, select your style, and then the face upon which to apply it. You may need to rotate/resize the texture to get a proper representation.
http
I can't remember the details but I think at the assy level this allowed him to show only certain part sketches.
However, this was several years ago and my memory aint what it was.
Just had a look at this and there is no way to get at the layers of a part or sub-assembly while you are in the parent assembly.
What you can do, however, is create sketches on different layers in the parent assembly, or different parts of a sketch and then show and hide those layers.
So you can only show/hide layers in the active file.
Not much use really because you could just create different sketches.
bc.
Quadro FX4600.
I'm pretty sure they found a way to only show the logo sketches, cause otherwise there'd be a whole lot of swept feature paths etc showing at the next level.
I think you set the layers to invisible in the part itself.
You are correct - putting sketches on different layers then hiding the layers in the part turns off the display of those layers at the assembly level.
I'm giving you a star.
Mind you it could be really confusing - I would have spent hours trying to figure out why a particular sketch wouldn't diplay.
bc.
Quadro FX4600.
