Internal corrosion in SS 316L tank at liquid interface
Guys,
There was ring of rust (corrosion) found at the internal surface of a SS 316L tank at its liquid/air interface. This tank is 3 ft in diameter and 5 ft in height. This tank is above ground standing on three legs on a third floor of a building; it is also connected to piping system, and is grounded. This tank contains a solution of ALPO4 and NaCl with a pH 5.2. I was wondering if catholic protection or sacrificial anode can be used at arrest this corrosion. Please suggest any solution.
RE: Internal corrosion in SS 316L tank at liquid interface
Cathodic protection would contaminate the product as the anodes corrode.
Good luck
My product has Cl- OH- H+ ions padding with N2 will still stop corrosion?.
Can we use Impressed Current Cathodic Protection to the SS vessel which can inhibit rust inside at the liquid/air interface?
I would look to replacing the tank with a material that can handle the chlorides. I would seriously look at Titanium.
Q1. how about using Hastelloy alloys for pH range of 5-7 in the presence of Chloride ions
Q2. Is Titanium effective for pH of 5-7 in the presence of Chloride ions
Please advise
You don't need Ti or a Ni based alloy.
Can you tell, is the corrosion on the zone just above the liquid, or just below?
Plymouth Tube
S
Corrosion & Rust Prevention Control
The corrosion on the zone just above the liquid. The temperature is room temperature with 15% Nacl sulution.
Th splash zone with is a problem is an area where you can have problems with many material that would other wise be acceptable in the liquid or vapor space. the reason being that all the bad actors tend to concentrate in this area, so if by some means you can keep this area flushed with the process fluid if will help with when using any material of construction.
S
Good advice thanks, can you suggest what type coating should be applied and how it is done.
The post doesn't indicate that the liquid level varies, so splash zone (still wet from waves or tidal motion) doesn't apply.
Raul Castillo, a NACE corrosion instructor with Dow in Freeport, Texas, is a world-recognized expert on CP in process equipment. If you have any questions on water-phase corrosion, he can help. His contact information should be easy to find on the Internet.
If the liquid level is fairly constant I would look into splicing a band of 6% Mo super austenitic SS into the tank.
Plymouth Tube
if this is not possbile or you want to fit and forget.. then i suggest the metal clad..
here you can find a descritpion of coating for SS
http://www.bssa.org.uk/topics.php?article=119
S
I'm sorry, the data I have is proprietary, so I can't reference these internal reports/guidelines.
If it were my tank I'd use a cladding and forget it. Materials are cheaper than labor, and you don't want to spend a lot of time on inspection. Remmember, the tank is small enough to stand on legs.
