Error opening file for NASTRAN F06
Hello I am French and I work on NX6.
When I made a simulation for a room with a grid at the resolution I have no result and there is an error message: "Error opening file for NASTRAN F06.
Does someone could help me because it is a real problem.
Thank you in advance
RE: Error opening file for NASTRAN F06
Je n'ai pas. F04 fichier. Les seuls fichiers que j'ai sont le fichier. Prt, _i.prt fichier, fichier. Fem, fichier. SIM,. Dat et fichier. diag.
Lors du lancement de la résolution, la vitrine de la marque informatique "Lancement du calcul NX Nastran ..." rien d'écrit dans la fenêtre.
Sorry I did not put the correct translation.
I did not .f04 file. The only files I have are the .prt file, _i.prt file, .fem file, .sim file, .dat file and .diag file. At the launch of the resolution, the monitor computing brand "Launch of NX Nastran calculation ..." and there is nothing written in the window.
Otherwise I was told to declare environment variables, but how do we do?
Sorry but I do not understand German.
I was joking, I'm afraid my French is very rusty.
A .f04 file lists the model build and analysis process, so your .diag or .dat might be a good place to look. .f06 is the results file, so all i can really see is that the build process didn't even get that far -even if the run is not successful you should still get a .f06 with the ERROR in it.
Have you tried contacting support?
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
Please check whether you have write and read permissions in the folder where you are running your Nastran deck.
