Modelling wear in Abaqus
Does anyone have any experience modelling wear in Abaqus, e.g. surface profiles, debris generation and volume lost after 5 million cycles? I have read some papers published this but wondered how much work is really involved and if this is something that abaqus is able to handle?
RE: Modelling wear in Abaqus
3.1.8 Tread wear simulation using adaptive meshing in Abaqus/Standard
I will go through this.
OptiEng
OptiEng
OptiEng
*HEADING
*restart,read,step=2
*STEP,INC=300,NLGEOM=YES,UNSYMM=YES
2: ABLATION
*STEADY STATE TRANSPORT,INERTIA=YES
3.6E5, 3.6E6, , 3.6E5
*RESTART,WRITE,FREQ=1
*print,contact=yes,adapt=yes
*adaptive mesh,elset=TREAD,FREQ=1,MESH=4
*adaptive mesh constraint,type=velocity,user
NADAPT,1,,5.E-13
*adaptive mesh constraint,constraint=lagrangian
NADAPT_LAGR,
*END STEP
Rob Stupplebeen
thanks Rob, just wondering did you write the section above or did you find this from another input file? and can I just add this to one of the input files?
OptiEng
That was in the file you posted. Just open it with a text editor. I think that Abaqus forgot to include the actual model information or you are suppose to add this to another INP. I hope this helps.
Rob Stupplebeen
Look, i was reading about steady state transport, but really i don´t understand anything,
How can i generate the mesh? it is not clear..
i treid to run the input example one, but i don´t have the old one). Maybe It is very difficult.
Please help.
Thank you
I was reading the abaqus manual for learn something about the analysis by steady state. it is about my big problem, two discs with its angular velocity, and i read that for this problem it is better do it by steady state transport.
The problem is that i can´t understant how can i generate the mesh (revolve), do do you have a simple example explaining it.
Thank you
