view scale options
view scale options
i had a quick look in customer defaults and preferences, to find if i could set up a list of default scales when adding a base view, but couldn't see anything, is there a way i can set these up?, or a text file i can edit?
RE: view scale options
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
File > Utilities > Customer Defaults
Pick "Drafting" category
Pick "Standard" tab
Pick your drafting standard from the drop down
Hit "Customize Standard"
Then enter your Numerator and Denominator
For info I found this by opening up the Customer Defaults and hitting the binoculars search button and typing in "scale". You might find this useful for other searches...
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
in the scale drop-down when placing a view, will JonSelby's method do this?
