Question on the bolt length for tunnelling support
To calculate the bolt length for tunnelling support, I understand that the equation form Barton can be used. However, I found there two versions of the equation, which confuse me. I wonder any of you could know which is the correct one.
1) bolt length = (2+0.15B)/ESR
2) bolt length = 2 + (0.15B/ESR)
thanks
RE: Question on the bolt length for tunnelling support
I believe it's the 2nd one but I suggest that you confirm that. Googling might find a reliable source.
Ryan Coggins, P.E., S.I.
http://www.linkedin.com/in/ryancoggins
thanks msucog's reply!!
Why I have this question is because I found that when searching in the internet, I can find both:
e.g.
http://dk.nanoq.gl/Service/Hoeringsportal/Milj%C3%B8vurderinger/2010/~/media/7DAFB26DAF514599AA993E244729B9CF.ashx
and
http://mining.itb.ac.id/file/bahan_kuliah/TA4111_Klasifikasi%20massa%20batuan.pdf
are using the first one.
This really made me confuse as both information could be find in the internet that generally being adopted.
