Foundation wall or retaining wall
There is usually Inside Vertical Face and Outside Vertical Face for a retaining wall and a foundation wall. Which face is the "inside face" and which face is the "outside face?
Thanks.
Thanks.
RE: Foundation wall or retaining wall
If you find an engineer using the term IF or OF for a cantilever retaining wall, report him to Eng-Tips so that he may receive the "DUH" award.
BA
BAretired, I like the idea!
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
The tension face for free standing retaining walls (cantilever) is always on the side with the higher soil elevation.
The tension face for a basement wall is the side away from the soil as this condition is the same as a simple beam.
Mike McCann
MMC Engineering
Motto: KISS
I wouldn't agree with the use of tension face and compression face, as builders typically don't know the difference.
