Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The enviroment is simple, natural and efficient. The members are competent, educated and professionals..."
Geography
Ashman2k2 (Mechanical)
3 Mar 10 21:15
thread800-234092: Lock nuts vs. pinch bolts on suspension links
In reference to this previous thread, a very well known and awesome suspension guru/parts supplier for the Nissan Z32 has this idea implemented in his products and explains the benefit here:
http://www.splparts.com/main4/header/HybridAdjuster/index.htm
However assuming the majority of the load is carried through the first 7 threads I would think the strength is reduced compared to the same sized traditional lock nut design. Any thoughts?
CoryPad (Materials)
4 Mar 10 9:24
My thoughts are that this system provides a small benefit during assembly when using a particular component design and a particular assembly method.  If no effort is use fixtures during alignment, then sure, you need three hands to do things.
I wouldn't worry much about reduced strength.  All of these joints are oversized due to stress concentration of the threads, especially since they are non-preloaded.
TrackRat (Automotive)
4 Mar 10 10:04
That idea isn't exactly new... it's been around for at least 45 years that I know of. <LOL> It's been used on production car/truck tie-rod links for at least that long. The Porsche version is prettier than the clamp typically used on split shaft tie-rods that have been around since forever, but it's the same clamp principle. I personally like the jam nut but both systems work well.
Close Box
Join Eng-Tips® Today!
Join Us             Close
