belt guard aftercooler
when designing an aftercooler to fit on a belt guard is there a typical air velocity used from off the belt guard fan?
RE: belt guard aftercooler
you need to clarify your question.  A belt gaurd is an in active piece of equipment and has no fan.  Some sheves have fans designed into the spokes.
a beltgaurd after cooler is just a air cooled heat exchanger installed on a belt guard of an air compressor. here it receives a 'nominal' air flow produced from the belt guard.
I have seen references of them being designed (over all compressor hp ratings) from 10 feet per minute across the coil to up to 500 feet per minute. My question is if anyone has knowledge in designing these, what 'rules of thumb' they use in the air flow used.
