Gust effect factor ASCE 7-05
I am calculating the wind loading on a flexible structure and need to calculate the gust effect factor per section 6.5.8.2 and have hit a road block.  I have determined n for the three cases needed to calculate Rh, Rb and RL. Equation 6-13a is for n > 0, and Equation 6-13b is for n = 0.  In all three cases my calculated values for n are less than 0.  What do I use to determine Rh, Rb and RL for this condition.  I have doubled checked my values for n and they check. Any help will be greatly appreciated.
RE: Gust effect factor ASCE 7-05
Never mind, I had a mental breakdown and found my error.
