Transparency
Transparency
Is there any reason why it wont work for me? Im in an assembly, I right click on an object and press "change transparency", and it doesnt do anything.
Anything I should check to see why its not working?
RE: Transparency
Tony Greising-Murschel
Windows XP SP3 x86 (Don't ask)
Core i7 870 - 4GB
Nvidia Quadro FX 580
SolidWorks 2010 SP2.0
RE: Transparency
RE: Transparency
Joe Hasik,
CSWP/SMTL/MTLS
SW 09 x64, SP 4.1
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
RE: Transparency
No matter which object I try to make transparent, it doesnt work. Any other suggestions?
RE: Transparency
Can you apply the transparency via the Appearances manager?
Does the Display Plane flyout allow change?
Do the Hide and Suppress functions work?
Have you rebooted?
Have you re-installed the approved graphics driver?
RE: Transparency
Dan
www.eltronresearch.com
Dan's Blog
RE: Transparency
Can you apply the transparency via the Appearances manager? NO
Does the Display Plane flyout allow change? YES
Do the Hide and Suppress functions work? YES
Have you rebooted? YES
Have you re-installed the approved graphics driver? NO
RE: Transparency
- Toggle global wire frame and shaded mode
- Toggle wire frame frame and shaded mode from the FMT fly-out.
Now try, transparency.
~ BT
RE: Transparency
How do I do those 2 things? Thanks.
RE: Transparency
This function is available in the Heads up view tool bar. See this link.
Interface
FMT Display options
~ BT
RE: Transparency
Yea, I did all that, still doesnt work.
Everything seems to work fine except for Transparency.
RE: Transparency
RE: Transparency
RE: Transparency
~ BT
RE: Transparency
RE: Transparency
I tried both of those things and it still doesnt work.
Im sure its something simple that I accidently hit.
RE: Transparency
RE: Transparency
Dan
Dan's Blog
RE: Transparency
~ BT
RE: Transparency
2010 has been a big disappointment for our company. Robustness is now a thing of the past.
