glycol coil sizing
glycol coil sizing
to design a coil inside a glycol absorber(top) to cool
the inlet glycol by colder natural gas stream moving up the
column in a glycol dehydration system.
RE: glycol coil sizing
a coil to be located inside a glycol absorber.Iam looking
for suitable calculation procedure.Since the coil is in the
top section above the bubble cap the fluid outside coil is
natural gas.
Additionally i have another coil at the bottom of column.
The absorber has two sections, above gas inlet is the absorption section and below gas inlet is an integral scrubber section.Oil,condensate and water collects in the bottom and is continously drained.A bottom glycol coil runs through this section.
Presently i am looking for a simple calculation procedure
to size my coil and estimate total no of turns required.
