Mirror parts with bolted connection
What is the best way to mirror parts with bolted connections within an assembly (Inventor 2010)?
RE: Mirror parts with bolted connection
You are better off to use pattern by holes anyway because a bolted pattern does not pattern holes if you use the BC to create the hole.
