Strange rigid 2-D analytical rigid shell at post processing
I wondered if any knows why my 2-D analytical rigid shell becomes a tube after running the analysis and would this affect my results?
See picture attached
RE: Strange rigid 2-D analytical rigid shell at post processing
Try view>odb display options>sweep/extrude
If that's not it try changing the view to XY>turn off perspective view> and crank up the deformation scale factor. to see if it is actually not moving.
I hope this helps.
Rob Stupplebeen
Thanks again
OptiEng
Rob Stupplebeen
