Dimension colour
Dimension colour
Dimension colour
Digging up the past a bit, but this is a really simple thing I've been trying to do for ages:
Changing the dimension colour on all drawings (when changing just the settings in Tools > Options > System Options > Colors doesn't seem to work) - what you have to do is activate your 'line format' toolbar, and click the RH most option on, called 'color display mode'.
RE: Dimension colour
Or you could move the dimensions onto a layer with an assigned colour.
I am sure if you had called your Tech support person they could have told you that, if they couldn't then your support group is not very good at their job. I would have told you that little trick.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
For some reason, colors of entity types is in system options and not document options.  Layers choice mentioned above is your best bet to control that via the document itself.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
