Control Valve Dimension
Good day guys,
Can you guys point me to the right standard whereas I can refer the dimension (flange to flange) for a control valve? Usually, I will refer to ANSI/ASME 16.34 for other valves, but for control valves, there seems to be no exact standard for it. Should I refer to the same standard? ANSI/ASME 16.34?
Hope my question is clear enough.
Thank you.
Thank you.
RE: Control Valve Dimension
