Sample Gas transfer cylinder
Does anyone know of a manufacturer that makes a double acting piston/cylinder assembly that will allow me to purge a gas, at a pressure of 5-8 bar in a sealed housing, test the gas while it flows past a sensor and fills one side of this piston/cylinder, then, with a compressor, fill the op end of the cylinder to return the gas to it's parent housing. The cylinder volume should be approx. 600 cubic inches making the ID around 10" and the stroke 18-20" (roughly). "Sorta like a big Bimba cylinder". Thanks
RE: Sample Gas transfer cylinder
