4340 phase diagram
4340 phase diagram
I'm doing heat treatments on a 4340 steel which is a nickel-chromium-molybdenum steel containing also manganese and carbon. Anyone knows which and how I can find the appropriate phase diagram for this low-alloy steel?
thank you!
thank you!
RE: 4340 phase diagram
http://
If you just need the basics of liquidus temperature, etc. then the Fe-C phase diagram should be sufficient:
http://ww
