Vessel Opening
Vessel Opening
I am looking at laying out a vessel prior to sending it out for budget pricing. For our layout we are potentially looking at having two 20" opening in a 2:1 semi head for an agitator mount and a manhole entrance. To prevent interference of the nozzles the manhole opening would have to pass through the knuckle region of the head. UG-37 gives instruction for reinforcement of openings within 80% of the head diameter, and from what I can see there is no guidance for openings encroaching outside of this area. This leads me to the conclusion that having an opening encroach on the knuckle region is bad design practice. Is this the case and does the PRV code provide direction for this. Any insights would be greatly appreciated.
Thanks in Advance
Alex
Thanks in Advance
Alex
RE: Vessel Opening
RE: Vessel Opening
Yes I am using Section VIII, Div 1. Thanks for answering my question.
RE: Vessel Opening
See code interpretation VIII-1-98-117.
